What prop should I Use
I have a 40' fountain with "3's and im running a 26p 3 blade clever prop. I would like to go to a 4 blade but not sure what size pitch. Any ideas?
Re: What prop should I Use
Please give us more info on the boat and power package(rpm and speed,desired rpm, etc.). Also, what diameter are the current propellers?
Its a 1987 40' fountain with twin 509's with 177 b&m blowers, 5000 rpm 70mph. I hope that helps
What's your gear ratio and propeller diameter.
Do you know the X dimension of the drive or better yet how far under the boat bottom is the centerline of the prop shaft? |
| All times are GMT -5. The time now is 11:58 PM. |
