Need to borrow a set of Bravo 1 28's
Im doing some prop testing and need to borrow a set of 28 bravo 1's. Ill pay shipping both ways, and if I do anything to em, Ill pay for em.
Re: Need to borrow a set of Bravo 1 28's
Our Prop Fitting Program is avaiable to you, if you need it! Feel free to call me anytime.
Julie Throttle Up Propellers 727-531-2255 |
If You Have Those Hydro's I Would Try Them Before
A Bravo. |
We have those too!
Julie |
Julie
Do you have any for #6's ?? Jud |
We should have a full line of test props for #6's by the time the season starts.
Matt |
Matt can you run some calcs to help me figure out were I will be as far as props and speed.
6600 LB boat 24 Degree V w/ delta pad/ no steps 557s, 6000rpm, 660HP/722Ft.Lbs. Arneson Surface Drives 1.36 ?? (I'm still waiting on these) Here is where I was Before rebuilds 502s, 5400rpm, 500hp/565 Ft.lbs Bravo 1s w/ 1.5 24 Hydros 76mph Thankyou Jud |
We also have a complete line of Bravo 1 propellers for testing should need them.
JShoup, you will slill be in the mid 20's for pitch in order to turn the higher rpm with the higher gear ratio. |
| All times are GMT -5. The time now is 02:53 AM. |
