-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   241 Liberator prop (https://www.offshoreonly.com/forums/prop-talk/123116-241-liberator-prop.html)
throttleup 02-23-2006 08:03 AM
Re: 241 Liberator prop
What is the weight of the boat "Wet"?
What is your gear ratio?
Julie
jmherbert 02-23-2006 01:12 PM
Weight of boat is 4000-4200 wet (best guess, the weight I have seen on these is 4000 dry with BBC)
The gearset is 1.50
The old owner had a cheap stainless 15P 3 blade and the boat would top out at 42 @ 4500 on a 350 Mag carbed.
James
gettin wet 06-10-2008 03:45 PM
My buddy just bought a 88 or 89 241 Liberator. It has the single Ford 460 OMC w/ King Cobra drive. It has the stock prop. He was wondering what prop would be good for it? Any ideas?
hoozeyurdaddy 06-10-2008 10:32 PM
Originally Posted by jmherbert (Post 1634860)
I have a 241 liberator with a single 383 (380-400hp) alpha. I have not yet got the boat on the water, so when I start I would like to have a good idea of what prop I should try.
Anyone have a good idea?
Thanks in advance
400HP Alpha? Be easy on the throttle coming up on plane, and get a drive shower for it, prop it for the higher side of the rpm, it will make it easier on the alpha out of the hole and reduce the amount torque on the drive.
Larry
markt111 06-11-2008 07:53 AM
the 3 blades run well on that setup with a deep drive, try a Mirage Plus, enough blade to carry your heavy boat
gettin wet 06-11-2008 10:24 AM
What pitch? And this is probably a stupid question :party-smiley-004:, but what rotation (RH?), since it is a single engine boat?
hoozeyurdaddy 06-12-2008 07:52 PM
Try a 19P to start, that will give you some info: as to what it will need, 99.9% of the single engine boat's run RH props.
