Props for twin 5.7
I have a 1986 Daytona with twin 260 HP stock small blocks. At the end of last year I changed the drives and now have counter rotation Alpha 1s. I also went from the 20P 4 blade aluminums to 23P Mirage props. The boat is now running 61MPH at 4400 RPM.
I am considering a set of 21P Revolution 4 blades. Will I loss my speed by dropping the picth or will I gain by getting into the power range? What is the optimum RPM? |
Re: Props for twin 5.7
The range of your motor is 4400-4800 RPM. You are running at the low end of the torque band of your motor and probably experiencing decent cruise speeds for your set-up. However if you are looking for greater top end then you should increase your RPm to 4700-4800 RPM at WOT. You could drop down to a 21P or lab you 23P to do so.
Julie |
Actually you are on the high end of the torque band and the low end of the recommended WOT range below the max horsepower rating.
Your slip is low. Running the Rev 4 21's will more than likely not help the top end. They will increase acceleration, and keep you on plane at lower speeds and rpm's. Your top speed will stay the same. If you are looking for top speed, Lab Finish the Mirage Plus 23's. We have a set of 21 and 23 Revolution 4's if you would like to try them. I also have another brand of 21 4 blades that I think will work excellent on your application if you are interested. |
Thanks for the info.
Sounds like I should forget the 21s and concentrate on adding some power and lab the props. The boat is bone stock including exhaust through the drives. I would like to get closer to 70MPH without major engine work. Exhaust, Ingition and Carb should help. I know I need some 383s but it's an old boat on a budget. Should I wait until the engine mods are complete before I have the props done? One of the props does not have a flow torque hub. Should I get another? |
Definitely do any engine mods you are considering before propping out the boat. Otherwise we will end up doing it twice.
The 21 Rev 4 may still be worth experimenting with when the time comes. Especially if you decide to wait on the mods. We can supply you with a new Mirage but again, use what you have to begin the dial in process. No sense investing on propellers till the end. Props should be the final piece of the puzzle. When your ready, Let us know and can supply you with the test props you will need. |
Thanks It wil give me a place to start and wait to do the props until I get more power.
I'd go with a couple of 502s, hee hee. See ya at work.
Yes, Brett is correct I should have said Power Band of the motor! Sorry.
Julie |
Hey Ginger
Just trying to keep up with you guys. I think I'll have to ditch the GPS and get a happy speedo. Unless you want to trade a couple of 502s. Maybe we can go to Winny so I could keep up. 45 MPH!!! Are you planning on Sebago? There are more pictures of your boat on their web site than the pace boat! Start waxing. |
Hello Yikes,
As far as Sabago goes, we got a wedding in Colorado that weekend; but we're gonna go to Winni July 8th for the Easter Seals run. We'll hit Sebago some weekend in July to go through the locks; if you're interested let me know, maybe we can hook up. Talk to ya later. |
I have a 29 scarab with 350 carb mags. I run 23p laser 2's @ 46-4700. Tried the mirage+ 23p but just can't turn em up enough. If you get the power up a bit they would work nice , my bud has the same boat w/350 mag mpi's runs at 4900 with the mirage+ 23's. My motors were in bad shape , re-powered this winter , new merc long blocks transoms and drives. Hopefully all will remain the same. The boat came with the laser 2's , my bud had to switch when he went to the mpi's. The lasers were hitting the rev limiters with the extra 30 hp per side. Good luck!
Now that's encouraging! I think I can get an extra 30 HP with a good exhaust and an intake change. If I can get to 4900 with the 23s I will be happy. (for now) Thanks Hustler
| All times are GMT -5. The time now is 12:26 PM. |
