turn around time to lab props
01 35 twin step fountain lighting runnin factory labbed 30 bravo 1s max rpm 5100 looking to get 3 -400 rpm more on the done 500 efis with a rev limit of 5700 whats the turn around time to get my props labbed
Re: turn around time to lab props
If your props have already been lab finished they wouldn't need to be lab finished again.
If you want to increase your rpm 300-400 that may be difficult to do, properly. Also if your props were thinned too much during the original lab finish that could hamper re-working them. Are your current performance numbers 5100 after the motors have been re worked? As far as turn-around time we are now about 2 weeks behind. That will most likely increase as we approach the summer. Matt |
If your 30's have already been Labbed by Mercury Racing, getting 300-400 more rpm will only give rpm and not speed. De-pitching and cup work will bring the r's up but the speed will stay relative. In order to pull 30's at 5700, the horsepower has to do it. I'm also unclear as to whether the 5100 is with 500's or after the work and rev limit has been adjusted.
| All times are GMT -5. The time now is 11:27 AM. |
