-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   wtf happened? tried a 28p bravo one (https://www.offshoreonly.com/forums/prop-talk/129852-wtf-happened-tried-28p-bravo-one.html)
BajaRunner 05-11-2006 10:52 AM
I am running a set of bravo one's 26p's labbed by throttle up with no cup. turning them at 5600 rpms.
Tried bone stock 28's and could only turn 4600 rpms. slip numbers were better with the stock, but why only 4600???
2000 36' baja outlaw, twin hp500's
Panther 05-11-2006 11:20 AM
Re: wtf happened? tried a 28p bravo one
I had a similiar problem with the 28's. Maybe they're a larger diameter?
I was testing 28's and could only turn 4600, tried 24's went to 5700, then 26's to 5300.
FASTERDAMITT 05-11-2006 05:07 PM
Interesting!
BajaRunner 05-15-2006 02:52 PM
ttt
bbladesprops 05-16-2006 09:22 PM
Each application is different. 28 B1's have their own personality too.
Your current props may be able to be adjusted furhter to improve your performance. Where do you need to get to? And where did you start at?
Gordo 05-16-2006 10:24 PM
You're turning 26p's at 5600 rpm?
Are your HP500's stock? If so, the rev limiter should have held you at 5350rpm.
Panther 05-17-2006 08:34 AM
What's your feeling on cutting the diffuser rings off?
