Prop for a Pantera 24
I've tried a Mirage Plus 25, Mirage 25 and Turbo 1 25 so far. Two people and about 20 gallons of gas.
Mirage Plus gave me a max speed of 68-69 at 4700-4800 rpm. Porpoised in the mid if you didn't drag some tab but not at WFO. Mirage gave me a max speed of 72-73 at 5000 rpm. Porpoised the same in the mid and a slight porpoise at WFO. Turbo 1 gave me 71-72 mph but bounced off the rev limiter. Similar handling to the Mirage but did do some crazy chine walking for a few seconds when the trim was trimmed in a little too far. Lesson learned and it didn't happen again. I have been running with the standard mirage and overall I am happy. But I always wonder if it could be better. I've found the boat to be VERY tab sensitive. Definitely has a lot of natural bow lift. I also have to drag the port tab more than I thought I would to run level, even at WFO. Also, running in boat slop I have to drag some tab(tabs about nuetral). Honestly it FEELS like a prop that had more stern lift would run the boat flatter and allow me to rise the tabs higher. But I could be way off there. I love the boat so far but I would really like to run a consistant 70+ mph and 74-75 with the occasional light load. I would definitely like to be able to run harder in the slop. Less porpoising would be a bonus but not a huge deal. Boat has a bone stock 502 mag (415 hp). Propshaft is about 4 1/2" from the bottom of the boat. I was thinking about trying a QIV or maybe a Bravo 1, although I heard the 24 didn't like the Bravo 1. Any suggestions? And yes, I know I am trying to have my cake and eat it too! :D |
Re: Prop for a Pantera 24
On my 24 Pantera (496 HO Mag with Bravo Drive, I run a 26P 4 blade. It has made all the difference. Prior I ran a 25P mirage plus. Jeff
YOu should really post this in the Panterasection. There has been a lot of testing on the 24. There are a few props that work well on the boat dependant upon your goals. The Hydro P5-X was the real surprize of the 05'. Joe really likes the QIV's on the boats.
Julie |
Julie |
Hey Noboat,
How are things up there on that big lake? I ran a Mirage +, Turbo Vector, and Bravo 1 on my 1989 24' Pantera. The Turbo was the fastest but the B1 was the best all around. My Pantera only when about 63mph with a 330HP. I have run Mirage +, and Bravo 1 props primarily on my 1997 24' Superboat. A stock Mirage + is faster than a stock Bravo 1 but it blows out too easy. The Bravo 1 requires a lot of trim to get the boat to run fast, but is pretty good over all. This year I sent my 28p Bravo 1 to BBlades to tweak. A night and day difference after Brett work the prop. The boat runs fast with vary little trim and is vary stable. I only use my K-planes in the rough or with an un balanced load. I have the same power as you, 502MagMPI, and with 2 people and 30gal of fuel, 75mph (gps) @ 4900 rpm... :D I did also have a chance to try a Hydro P5-X. Great prop for these boats if you are willing to pay the big $$. T-Mone has a 2005 24' Pantera with big power and runs a P5-X. I have run with T-Mone, and his boat handles the rough like no 24' boat I've seen. T says the 5 blade does help... |
Pat things are good! :D
After speaking with Tmone and Jo today I want to try a B1 and a Quad IV. I keep getting mixed opinions on the B1 but I want to try it for myself. Jo said he ran a B1 on the Army race boat and it worked great. |
noboat:
I tried a 25 QIV-X on my 28 Pantera single 525EFI and couldn't get more than 63. Have a 26 B1 Labbed and can get that to 69. My 24 B1 will get me to 73 but close to hitting the Rev Lim. I'm going to try a 23 P5-X from Hydromotive. To see what that does. T-Mone really loves his P5-X on his 24 Pantera. You may want to try the same as T-Mone. Ron |
After speaking with Tmone and Jo today I want to try a B1 and a Quad IV. I keep getting mixed opinions on the B1 but I want to try it for myself. Jo said he ran a B1 on the Army race boat and it worked great. Your boat will run more stable in the rough with a 4 blade vs. a 3 blade for sure. Like I said earlier, BBlades modified my Bravo 1 to give more bow lift with less trim and I am now vary happy with the B1 on my boat. The Hydro P5-X has a different feel than a Bravo 1. The P5-X has more stern lift and also seems to lift the whole boat. I was also surprised that my boat was just as fast with the 5 blade as a 4. |
Originally Posted by Full Throttle 525
noboat:
I tried a 25 QIV-X on my 28 Pantera single 525EFI and couldn't get more than 63. Have a 26 B1 Labbed and can get that to 69. My 24 B1 will get me to 73 but close to hitting the Rev Lim. I'm going to try a 23 P5-X from Hydromotive. To see what that does. T-Mone really loves his P5-X on his 24 Pantera. You may want to try the same as T-Mone. Ron Bummer that the new prop didn't work. It sounds like a different receipt for labbing at 26 B1 would be the ticket. Let us know how the P5-X works... :cool: |
Originally Posted by Pat McPherson
It does require a lot of trim to get these boat to run free in calm water with a stock Bravo 1, and the sweet spot is small before the prop will start to slip.
Pat, how much more "torque roll" to port did you get with the B1 over a three blade?
The boat runs smoother and simply performs better all around with the 4 blade. The only thing a 3 blade was better for was top end speed and now with a properly labbed prop, the 4 blade is just as fast. I do notice more roll to port when the drive is trimmed in/down. Once my boat is up and running I don't use the tabs much unless I have an unbalanced load or in the rough. |
I have not run a 3 blade on my boat in a couple of years but I think less roll with a 4 blade vs. 3 blade.
| All times are GMT -5. The time now is 03:47 AM. |
