Herring Props
here is the delema, just bought a Fountain 42 EX, with 525's and stock XR's. I have run the stock 32 Bravo's Merc. Labbed 32's and the dealer has a set of 6 blade Herrings that I am trying to get a hold of. Has anybody seen that big of a difference from upgrading to Herrings or should I just make an offer on the labbed Merc. 32's and call it a day. Is all of the stuff I am hearing about the Herring true or will the Merc. labbed pops due the trick.
P.S. the labbed props showed a big improvement over stock. should I just be happy there??? or any other idea's??? |
Re: Herring Props
To some degree it will depend on how the boat is set up.
What are your current performance numbers? WOT rpm and speed with the stock 32's. |
Re: Herring Props
you may see a couple of mph... the only way to know is to try them...also is 2 mph worth the $$$$
Re: Herring Props
Re: Herring Props
BZ, .....my stock 32's go to 5300
Re: Herring Props
I think you should address the slip issue you have now;
How does the boat get on plane? Is there a rooster tail at max speed, if so how high? How much drive trim do you need to get top speed? I would look into what's causing so much prop slip. If this is a new boat it wouldn't be uncommon for the drives to be mounted a little high. If you have the performance sheet from Fountain it should tell you what the top speed and rpm was before it left the factory. Take a couple mph off whatever that sheet says and then you have a realistic goal to shoot for. You may benefit from the 6 blade props on your boat given the slip you have now. Matt |
Re: Herring Props
It was really great talking to you today. With a little work, patience and creativity we should be able to find a little more in her! I am sure of it!
Stay in touch and call me after you finish testing. Julie |
| All times are GMT -5. The time now is 03:20 AM. |
