Bent Bravo One Blade
I bent a blade on my Bravo one Prop. :mad: It is about 2-3 inches in from the tip of the blade and about 3 inches bent backwards like someone just grabed it and pulled it back. :confused: Can this be saved or is the prop done for?
Re: Bent Bravo One Blade
It can be repaired. We repair props like that everyday. The radius of the bend will determine exactly how it needs to be repaired and if the bend will effect the future structural integrity of the prop.
Most of the time it's not a problem and the prop will perform and look better than it did when new. Matt |
Thanks Matt i'll be giving you a call to check on time and cost
Thanks Rob |
| All times are GMT -5. The time now is 12:09 AM. |
