-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   oil leaking Bravo one (https://www.offshoreonly.com/forums/prop-talk/143277-oil-leaking-bravo-one.html)
Fboat42 10-20-2006 09:37 PM
I have a Bravo one drive that drips oil slightly from the low water pick up. i have changed the seals between the upper and lower sections. Any ideas on whats leaking
Griff 10-20-2006 11:02 PM
Re: oil leaking Bravo one
Thats would I would thiink also.......the seals between the upper and lower. I don't know if oil can into water intake anyway else.
BTW, you would be better off posting this in the Technical Q & A section.
Fboat42 10-21-2006 06:04 PM
thanks
