-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Prop design??? (https://www.offshoreonly.com/forums/prop-talk/144161-prop-design.html)
bcarpman 11-01-2006 04:47 PM
Prop design???
I'm trying to learn a little about prop design. I've search through this forum, and read a couple of books. Today I was looking at some photos of props
The first one has straight trailing edges:
http://i11.ebayimg.com/05/i/08/cc/bb/a8_1.JPG
While these have much more curve to the trailing edge:
http://i9.ebayimg.com/06/i/08/c0/1a/fa_1.JPG
They're both 24 pich bravo 1 performance props. What assumptions would a prop expert make after looking at them??
thanks
bbladesprops 11-02-2006 11:32 AM
Re: Prop design???
I would assume that the top picture is not a Bravo 1 propeller. At least not from the picture I am looking at.
Though hub exhaust stern drive intended cleaver top pic (Q4). More stern lift.
Though hub exhaust stern drive semi round ear bottom pic (B1). More bow lift.
bcarpman 11-02-2006 04:48 PM
Re: Prop design???
The pic of the top prop is off the interent, but is identical in appearance to an intimidator Q4 that someone gave me to fit my bravo 1 drive. The bottom props are shaped like what I have on it now.
If I'm currently running a three blade but with blades shaped like the second props, and I'm running pretty flat on smooth water without tabs, and need a decent amount of tabs on rough water, would I then expect to much bow down with a four blade cleaver like the first pic?
I'm also going up in power and taking about 80lbs off the stern.
thanks
