cracked blade labbed Bravo 1 32?
BBlades or ThrottleUP
Can a cracked blade that extends about 2/3 thru the blade half way down the blade be repaired? There is no visible offset at the crack. Local shop told me they don't repair cracked blades. If you can repair a chewed prop from hitting bottom, what would be the concerns with repairing a crack on an otherwise perfect prop? |
Re: cracked blade labbed Bravo 1 32?
The metal along the weld can be compromised.
Something that big we consider unrepairable. Can we do it, yes. Do we suggest doing it, no. |
Something that big we consider unrepairable. Can we do it, yes. Do we suggest doing it, no. Taking this one step further; could you replace the blade, remove at the hub and replace the whole blade? |
No we won't do that.
It's scrap!
You can find someone to weld it and keep it as a emergency spare. It will crack again sooner or later.
The money you save trying to fix the prop, could cost you double in the long run. If its repaired and throws the blade it can do serious damage to the drive also. Dont chance it. Buy a new prop. :D :D
1 Attachment(s)
Take a pick
I have a new one $400.00
Good info. Thanks. Already bought a replacement. Strip, that picture could be my prop. Exactly the same crack placement and length.
I lost a blade on one it took out the gimble pin from the vibration |
| All times are GMT -5. The time now is 02:06 AM. |
