How Bent is Bent
I recently bought my current boat and was looking at the prop today. By clamping an allen wrench to the splash plate and turning the prop I noticed that there is about an 1/8th of an inch difference front and back between the blades on my 4 blade Bravo prop.
Is this far enough off to be a problem? The prop seems to perform fine as far as RPM goes but the top speed and cruising speed seems slower than it should be. |
Re: How Bent is Bent
What you measured is not unusual for a stock cast prop. If you are satisfied with the performance and don't notice unusual or excessive vibration it should be fine the way it is.
2 Attachment(s)
This would qualify for " how bent is bent "
Ouch! :eek:
Julie |
This would have been the first season I made it though without the props being trashed, it happened on my last time before storing it ! @#$% &%*$
Sorry to see and hear Jim!
Check your email. Take care. |
| All times are GMT -5. The time now is 09:53 PM. |
