-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   312 fastech props (https://www.offshoreonly.com/forums/prop-talk/156480-312-fastech-props.html)
dave krehbiel 04-22-2007 09:30 AM
312 fastech props
I have a 99 312 fastech with what the salesman said were labed 26p props. I get good perfomance out of them, but I bump the rev limiters at 5100 rpms and about 74mph. would I be better off with 28p props and would that knock my top speed down.
gsmith9898 04-22-2007 03:47 PM
they would probably bring the speed up a little and lower the rpms off the rev limiter.
bbladesprops 04-22-2007 07:18 PM
Yes, trying the the 28 stock props will help to deternine where you ultimately need to be.
t500hps 04-22-2007 09:15 PM
You must have the 454 MPI (310HP version). I'm pretty sure that boat came with stock 28's from the factory....and Formula tends to do their homework before putting a boat out there (I had a 98 312 with 502 mags and 30 pitch 4 blade bravos)
dave krehbiel 04-23-2007 01:57 PM
They are 385's with 1.5 brovo's and these are not the stock prop's, someone messed with it before I bought it. I would assume that 28' would work better. Now do I buy lab finish or stock?
gsmith9898 04-23-2007 02:03 PM
I have a set of labbed 28'sfor sale.
t500hps 04-23-2007 03:14 PM
Are you sure they are 1.5 bravos.....every 312 I've ever seen came with 1.65's. (Drives could have been switched). Best thing to do is get a set of "perfect/new" props and start running/ testing her. I'm doing that now with new motors and using a trued set of props will help you figure out where you need to go.
dave krehbiel 04-25-2007 10:30 AM
Thanks for everyones help I will have to find a place that will let me try diferent props, and there is only one local prop shop in my area. I am afriad if I keep bumping the rev limits That I will damage something.
I may get a hold of gsmith9898 if I find 28's are a good fit.
