-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   3 blade to 4 blade (https://www.offshoreonly.com/forums/prop-talk/156852-3-blade-4-blade.html)
unbroken 04-26-2007 04:06 PM
3 blade to 4 blade
I recently went from 3 blade 23" mirages to 4 blade 23" Revolution 4, 4-blades(thanks Full Throttle marine:evilb: ). I expected a little bit of a loss of RPM's, and speed. I went from 66 GPS to 64.5, and 5000 RPM's to 4700 :eek: . Now for my question. Normally with the 3 blades I ran my trim best at 6 units. Today with the 4 blades I ran my trim up further, to 8 units then to 9 units, (full up trim using the switch on the throttle((Not using the trailer switch))) and I gained back my 5000 rpm's and 65.5 MPH. Is it normal to run the trim higher with the 4 blades than the 3 blades, and is this due to the stern being higher? Also, am I making the gimbal bearing work harder by running it that high?
StillHaulin@63 04-26-2007 04:26 PM
IMHO, as a rule, yes!
I have found that a 4-blade prop provides more stern lift than a 3-blade due to the additional blade surface, and in the case of a Bravo/1, the increased diameter of the blades. With this flatter hull attitude, the additional drive trim is necessary to provide less wet surface on the hull and thus, more RPMs and potentially, more speed.
I can't speak to the gimbal question, but it would seem to me that it would be designed to accomodate any standard trim setting available.
throttleup 04-26-2007 04:39 PM
StillHaulin you are correct. The 4B propeller induces increased stern lift, so more trim may be required to achieve desired bow lift.
Julie
unbroken 04-26-2007 05:09 PM
WELL DAMNIT, I find out 5 days after the poker run. LOL. Thanks guys, Julie, still looking to lab them, figure my 5200 RPM goal is attainable.
throttleup 04-26-2007 06:46 PM
You just let me know when your ready.
Julie
bbladesprops 04-28-2007 01:46 PM
Tim,
I left you a voice mail.
unbroken 04-28-2007 07:17 PM
I received it and left you a PM. LOL
bbladesprops 04-29-2007 01:09 PM
Back at ya. The only thing we haven't done is talked via private email or met in person heheeheheh.
Talk to you later.
