-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Hydromotive vs Bravo 1 props (https://www.offshoreonly.com/forums/prop-talk/156873-hydromotive-vs-bravo-1-props.html)
Fast Forward 04-26-2007 08:35 PM
Just wonder what the performance difference would be between the Bravo 1 vs the Hydromotive Quad? I tried a Bravo 1 last year and it seemed to give my boat a little to much lift in the stern. Will the hydro do the same?? Years ago I had a Scarab anf the Hydro was by far the fastest prop for the boat. But that was 12 years ago and things have changed.
Johno 04-26-2007 10:02 PM
Hydro Quad was faster than the Bravo on my boat as well.
Call the Pro's ...Julie (Prop Goddess) at Throttle Up & she'll tell what's the better for your application.
throttleup 04-27-2007 08:11 AM
If you have a Powerquest as in your Avatar then you want to stick with the Bravo I props as the Hydro QIV will lift the stern even more so.
Julie
ziemer 04-27-2007 08:39 AM
Hydromotive also makes a Quad IV-X which is more similar to the Bravo (rounded blade tips), and from what I've been told is a more efficient prop. I have a 24" Q IV-X and it runs around 6-7% slip at WOT.
throttleup 04-27-2007 10:05 AM
Yes, the QIV-X is Hydros bow lifting propeller.
Julie
UNSANE 04-27-2007 10:26 AM
Julie, tried to call yesterday. Did you get my P5? Talked to Matt and sent it Tues. morning. Let me know!
throttleup 04-27-2007 11:22 AM
Yes, Gregg it arrived safe and sound!
Julie
Pat McPherson 04-27-2007 11:28 AM
Hey Ziemer,
Are running that Q IV-X on your Pantera?
If so, how does it compare to your M+ as far as top speed?
ziemer 04-27-2007 12:03 PM
Originally Posted by Pat McPherson (Post 2108190)
Hey Ziemer,
Yes.
In stock form it's slower. I'm going to have Todd at Hydromotive lab it for me and see if I can get it closer to the Mirage. The 24 doesn't get over the hump, and turn up like it should. I can only get 5000-5100 out of it. But, I also tried a 22" of the same prop and turned that one almost 6000 at 75 and change.
Unless Rob (Stormrider) had the prop cut into a M+, the Mirage I have is just a regular Mirage. I would like to try/find a 25" Mirage or Mirage + because I think that would prove to be the fastest and still keep the RPM's conservative (My 23 Mirage turns 5800+ @ 78 or so mph)
Fast Forward 04-27-2007 12:51 PM
Thanks for the heads up. The bravo I had was a lab finished so maybe I should try a stock
