Proper Thrust Washer?????
I just changed from quicksilver to hydromotive props on my TRS Drives. At first we put the thrust washers off of the quicksilvers behind the hydromotive's. One of the Hydromotives were binding up when we tightened the nut. We changed to a different type of washer and problem is solved apparently. Now I have 2 different type washers.
Does anyone know the proper Mercruiser code for the proper thrust washer for this set up? Or will they be OK the way they are. I am going to take this rig to tickfaw poker run and don't want something stupid like a washer to screw up my run. THanks in advance. |
Look at the washers you are currently using. They should be stamped 12-835467 1.
Originally Posted by bbladesprops
(Post 2113855)
THanks. THat is the kind of info I was looking for. |
| All times are GMT -5. The time now is 10:43 AM. |
