-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   30 eliminator Daytona which prop to use? (https://www.offshoreonly.com/forums/prop-talk/160242-30-eliminator-daytona-prop-use.html)
stangjeeper 06-07-2007 03:06 AM
I have a new to me 30' eliminator Daytona with twin stock 496 ho's,1.36 drives and 30p bravo 4 blade props.
The boat is very slow to plane and seems to be lacking power until it starts to roll over and the bow comes down, at that point it will blow the props out if I stay in it. Stock Bravo drives on extension boxes.
Any recomendations on prop selection?
Id like more hole shot and better cruise. Im willing to sacrafice some speed on the top to gain on the low and mid range areas.
gsmith9898 06-07-2007 07:25 AM
I have a set of labbed 28 bravos.
stangjeeper 06-07-2007 08:50 AM
send em on down to LOTO and Ill let ya know how they do lol.
Id like to try 28 bravo's but Im curious if a 5 blade may be better.
gsmith9898 06-07-2007 09:20 PM
I'll be over there next month.
stangjeeper 06-12-2007 10:10 AM
Any insight from the prop folks?
throttleup 06-13-2007 05:16 PM
What is the measujrements of your prop shafts in realation to the bottom of the hull directly in front of the drives?
Julie
stangjeeper 06-13-2007 07:39 PM
Julie
Pretty sure they are even with the bottom of the main hull. There is a small step up at the back just before the props. maybe 3" long. I can double check these measurements next time Im at the lake with the boat.
bbladesprops 06-13-2007 08:37 PM
Part of your issue is the gear ratio. I would rather see you with 1.5:1 gears. This would help the low end grunt.
Has anything been done to the props and what is your WOT rpm in standard load conditions?
Your X dimention sounds fine. Some venting as the bow comes over is normal.
stangjeeper 06-13-2007 10:27 PM
Still havent had a chance to go fully WOT. I was at 4600-4700 rpm and slowly climbing but ran out of Room to stretch it out any further. I agree with the 1.5 ratio but when I spoke with Eliminator today they said they only put 1.36 drives on the 30's,which I dont totally believe as a few owners with 30's have 1.50 drives. The props are just stock 30 bravo props from what I can tell.
