-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Prop pitch question (https://www.offshoreonly.com/forums/prop-talk/160930-prop-pitch-question.html)
jdub 06-14-2007 04:32 PM
Prop pitch question
If you want to run a motor at a set RPM at WOT and your current prop achieves this goal at 3/4 throttle what should you next move be? Will moving up a pitch (say 24 to 26) get you closer to your goal?
StillHaulin@63 06-14-2007 05:36 PM
Yes, moving up in pitch will get you closer to your goal.
jdub 06-14-2007 06:09 PM
Is there a rule of thumb on how much a pitch size increase will change RPM at WOT.
StillHaulin@63 06-14-2007 06:12 PM
The "rules" vary depending on hull, engine, water conditions, etc.
What are you running?
jdub 06-14-2007 06:29 PM
27 excalibur with notched transom, bravo 1 ratio 1.5 with propshaft 4'' from keel, carbed 509 with approx. 525 hp, Bravo 24 4 blade 5200rpm at 3/4 throttle.
StillHaulin@63 06-14-2007 06:38 PM
I'll bet a 26p Bravo/1 will just about get you there.
A 28p might be a bit too much load on the engine.
Get yourself close, then consider labbing for the fine tuning.
Julie & ThrottleUp has a prop testing program and probably accepts trades.
PS: I'm assuming you don't want to exceed 5500-5800rpm.
jdub 06-14-2007 06:45 PM
26 was what I was thinking too. Looking to spin around 5200-5400 tops.
StillHaulin@63 06-14-2007 06:52 PM
You could probably lab your existing 24p to reach your 5400rpm objective.
jdub 06-14-2007 06:56 PM
I guess its time to make a call...
StillHaulin@63 06-14-2007 07:01 PM
Be sure to give her plenty of detail and a good set of numbers to analyze ( RPMs, MPH, etc.)
You won't make a mistake following her suggestions.
Good Luck .....
jdub 06-14-2007 07:04 PM
Thanks. Battery was dead so no MPH. I'll have to go out again to get some hard numbers.
Griff 06-15-2007 03:31 AM
General rule is 200 rpm decrease for every 1" of pitch increase----with the same make of prop.
jdub 06-26-2007 07:48 PM
Well I ran a 26 Bravo and saw 82 GPS @ 5300. At this point I would say this is the prop for me. But I am still open to suggestions on what else to run. Thanks.
bbladesprops 06-26-2007 09:43 PM
Labbing a 28 is another option that will put you in the same rpm range (5200ish). Your current efficiancy will help to determine if Labbing is a good all around option. Your gear ratio will help to make the determination.
