Originally Posted by MrCIG
(Post 2190123)
Are you using the trim tabs to get on plane? Sometimes the tabs will take the water away from the prop and you won't be able to get on plane.
Mark |
Originally Posted by markku4444
(Post 2190319)
Hi i did not use the tabs, and this week i will try 4-blade 17,5x28,cleavers and drain out 200gal, of fuel before i try it again.
You will definately need to try smaller pitch props. It will get the engine into its power band. I would try something in the 22-24 pitch range.
Why do you think they are 6000-7000rpm motors???? Do you have dyno sheets???? With 620hp, 5500rpms is more likely. |
Originally Posted by Griff
(Post 2272925)
How did he get that from the Navy without holes being poked into it?
Originally Posted by excalibur32
(Post 2287042)
What gear ratios are in the outdrives? You should be able to spin more rpms than that with those props.
Originally Posted by PatriYacht
(Post 2292613)
HP to weight ratio in theat boat should put you in the 70 mph range with 24 pitch propellers turning 5400.
Check your recomended engine rpm ratings. I think you may be a little high in 6-7000. Because the propellers are now hooking up well enought to keep the slip % below 15, something must be going on with the engines to only allow 3000 rpm. |
| All times are GMT -5. The time now is 01:54 AM. |
