-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Lookind for a used B1 26 (https://www.offshoreonly.com/forums/prop-talk/164732-lookind-used-b1-26-a.html)
RJBBC 07-29-2007 07:06 AM
Wrecked our labbed finished B1 26 yesterday, dragged it along the bottom of the lake. Looking for another prop. We have a 2000 Checkmate 259 with an ugraded 454MAG about 460HP and 485lbs at 5000RPM. We need a prop that takes some of the porpoise out of our hull design and will run 5000-5100 at WOT. If there are any other props out there that will accomplish this I am all ears. Thanks in advance.
Rob
RBeyer 07-30-2007 08:17 PM
Rob
I have a 24 Hdro $275 near new.
Should be similar ask others opinion.
Send me a pm with E-mail I will send pics
RJBBC 07-31-2007 12:53 PM
Sounds interesting. I sent you my email address. What boat, power and rpms did you run this prop? Why are you selling it?
Rob
Donman 07-31-2007 02:55 PM
I was looking for a used 26p Bravo last week.
I had several offers from OSO members from $350-400 plus shipping.
I found a nice one on Ebay for $275, plus $15 shipping.
RJBBC 08-01-2007 02:35 PM
thanks,
Rob
Knot 4 Me 08-01-2007 03:08 PM
Rob
I think an Eliminator cat will take the porpoise out of your Checkmate! :boat:
RJBBC 08-02-2007 01:27 PM
good call:party-smiley-048:
ted lamparty 08-02-2007 03:40 PM
b1 4blade
If you haven't found A prop yet I have one you might be intrested in. It's a bravo one 4 blade, 26 pitch. It was labed finished by Throttle Up. It was set up for my Checkmate 259 Convincor. I had A little cup taken out of it to try to stop the porpoise and serious chine walk at speed. It workgood with my last set up, but I upgrade to A 580 CI. 690 HP. I can't use it now.
RJBBC 08-02-2007 05:00 PM
I found a prop shop that thinks they can fix mine. If they can not I told Vinny (454MAG) I would buy his. If these two options don't work I will be interested. What prop are you running with 690HP? How does the boat handle with the motor upgrade? Do you have hydraulic steering and performance tabs?
ted lamparty 08-03-2007 07:16 PM
prop
IMCO hydrolic steering, Dana trim tabs. Also upgraded to a XR drive. My boat still has a slight porpoise problem, I think it's caused by a too high X dimension. Checkmate used A high X dimension to gain more top speed. Mine was ordered with what I think was A 1/4" higher than what Checkmate normally uses.
