B1 to B3 What Props
B1 to B3 What Props
I have a Bravo 1 1.50 and am changing to a Bravo 3 2.0. With the B1 i am turning a 24 pitch prop with a lot of slip and was wondering what prop I should try. The motor is a 330 and the boat weighs appx. 4000 lbs.
I also have a 1/2" spacer any idea what its worth?
Thanks in advance Chris
Offshoreonly Advertiser
With that gear ratio change and harnessing the slip, you'll probably be back in the 24 range. You will need to get some type of base line with a 22-26 set.
[email protected]
[email protected]
raiseyourdrive
09-15-2004 08:23 AM
