Props 4 32 Outlaw???
Alright guys I am looking for some good advice on what prop choice will be best? I am looking at a 32 outlaw with t540's approx 625hp per motor. It currently has b1's with the extension boxs and 26p 4blade bravo props. what do ya think??
If it's 1.36:1 ratio drives, that's probably about
the right setup. |
its 1.5 sorry forgot to add that
Originally Posted by BIGZXXL
(Post 2441388)
The motors must like running 6000 rpm then. I have a simlar setup, but with less HP, and can spin 32 Bravo's to 5450 ( rev limiter) rpm. I have a relatively high X dimension, and the best props that work on it are 32 maximus's |
JT's right, w need more info.
I haven't taken possession of this one yet so I am not exactly sure of the rpms just yet but I am pretty sure these props are not exactly right for the power. considering that it is still set up for the stock 454's. at risk of sounding like a idiot what exactly is the x dimension???
(Post 2441912)
X dimension is the distance from the centerline of the crankshaft to the bottom of the hull ( directly beneath the engine). This translates to how far the propshaft is below the bottom of the boat. |
i run 28 lab finished, 515 hp per side. 32 outlaw and its for sale, going to cigarette.
Sacaja give me some more details about the boat. may be intrested.
bigzxxl
i sent you a email, hope you got it?
Originally Posted by sacaja
(Post 2442608)
| All times are GMT -5. The time now is 06:07 AM. |
