-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   27' Daytona Prop Choice (https://www.offshoreonly.com/forums/prop-talk/186783-27-daytona-prop-choice.html)
Ara 05-15-2008 05:14 PM
I have a 27' Eliminator Daytona Open Bow with about 900hp. Currently using a standard length lower unit with 1.35 gears, and a 28p Bravo I 4 blade. I am thinking of going to a 2 inch shorter lower unit. What would be a good prop top start with. The 28p ran 94 at about 5600 rpm (not full throttle if that matters). Thanks in advance.
orange26daytona 05-16-2008 05:28 AM
Is that on the limiter? I would want to know max speed before I changed anything. Then only change one thing at a time, that is the only way to know what helps or hurts. mine is standard length also, but 1.5 gears w 31 p b1. still working on setup too. if you try the short drive, let me know if you loose on takeoff. Have heard claims of no loss and claims of hard to get on plane. Good luck
gsmith9898 05-16-2008 07:15 AM
I put a two inch shortie on mine and went from a bravo 28 too a bravo 30
bbladesprops 05-16-2008 09:47 AM
Planning can go out the window on these boats with 2" X raises. However I know of applications where it remained acceptable.
You will need to go up at least 2"s of pitch. A 5 blade may be a option too but we will need to weigh the increases over the shorter and the 4 blade. A 1" depth change is also a option.
Ara 05-16-2008 03:33 PM
That is not on the limiter. Pretty sure my motor will turn at least 6400 rpm. The open bow boats are setup with the x 1 inch lower than the closed bow boats. I think I would like to go up 2 inches with a short lower and if I have planing problem, then I can add a 1 inch spacer. So Should I start with a 30p or go bigger with a 32 or 34?
Quent 05-18-2008 10:24 AM
27 Elim 5 Blade
ARA, I had a Lavey 27 cat with 930hp, 1:35 gears, 2" Shortie and ran a labbed BBlades 5 blade Maximus. 112mph. Great prop. I sold the boat and still have the prop. Its in OSO classifieds. Quent Call me if you like. 8657054948.
B BOATER 05-18-2008 06:09 PM
yes you can run a 1 inch spacer I did. We ran a 30 p bravo 1 Labbed ran the best. Didnt try a 5 blade because our slip was not very high. 1000 hp pfaff 1.24 gear. and a 1.35 gear.
