-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Proping a Checkmate Convincor 251 (https://www.offshoreonly.com/forums/prop-talk/187730-proping-checkmate-convincor-251-a.html)
CHEKT OUT 05-28-2008 09:50 PM
Hey guys, I'm in the process of dropping a 540 into my 1993 Convincer 251, Its nothing wild (500-550 hp), Im looking to run around 5200 RPM, any advice on a prop would be appreciated.
Thanks in advance
tony manzella 05-28-2008 10:08 PM
proping convincer
my W.A.G would be a 28pitch ,:evilb:
bbladesprops 06-02-2008 08:32 PM
Get a base line with something so we can go from there.
Otherwise get me a true wet weight and I'll run the numbers to get you within a inch or so.
Magic Medicine 06-02-2008 08:59 PM
Thanks in advance
Go with B blades, he did wonders for my old ZT 280!
IRONMAN 06-02-2008 09:51 PM
25 Mirage Plus if you have 1.5 ratio should get you really close. Or a Bravo1 26
CHEKT OUT 06-04-2008 10:37 PM
Hey BBladesprops, the net weight is 3700 lbs with a 7.5 ft beam and a 1.5:1 outdrive
Thanks for the info
