prop slip
I've seen the Bam site for figuring prop slip...
my question is how do you reduce it?? thanx mike |
what set up are you running now? give us a little info: and we can give some input, every boat is different and so are props, tell us more.
Changing props or changing drive height is the most common way to reduce slip.
Ok....
'03 280 silencer 496 ho bravo 1 x with 1.50 labbed 26 bravo 1 w.o.t 4900rpm speed is 64-65 mph? - I may need to recheck- will do this weekend thankx, mike |
yep...confirmed speed was 64 mph, 4900rpm, bravo 1 labbed, 1.5 xr drive, 496 ho
Originally Posted by verbi69
(Post 2647338)
4900 (rpms) X 25.3 (pitch) divided by 1.5 (ratio) divided by 1056 (factor) = 78.264 X 82% (slip) = 64.176 mph. |
I just spent an entire day testing props I was able to borrow......5 blade maximus got me as low as 10.9% at 4,000 and at WOT it was 11.X (can't remember)!!!!!
Looks like I'm buying anopther set of props!!! (My bravos came in at almost 19%!!!!!) |
Holly....how long do I need to keep scratching my head???
And yes with the gps speed... Thankx guys.... mike |
So with too high a pitch what is the next step?????
(Post 2648254)
Will do...thanks for the input.
mike |
I have a 25' Switzer. 454 Mag carburated Bravo 1. It has IMCO Thumper Power exhaust manifolds. I figure it is putting out 385hp. With a 23p Mirage at 5000rpm and 1.5-1 gearing it runs somewhere in the 60-62mph range and that works out to a 17%-15% of prop slip. Is that the best I should get out of this set-up or can I get somemore by playing with trim or going to a 22p Bravo 1?
Originally Posted by scottw
(Post 2735179)
| All times are GMT -5. The time now is 11:49 PM. |
