Switching prop rotation.....
I am currently running a RH Bravo 1 26 & I am switching to a Hydromotive LH P5X 24.
My question, do I have to do anything more than just changing the cables around on the shifter to make the rotation swap? I appreciate the input.... |
You need to reverse the cable connections at the shift bracket on the engine.
The boat may not like a LH prop. |
Originally Posted by Griff
(Post 2651134)
The boat may not like a LH prop. I've been told that by switching over to a LH prop, it will eliminate the "port list" caused by the engine torque. I have to drag the port tab to correct it right now, & I'm hoping to stop having to drag it. |
I've always done it at the shifter itself,
you will either get more or less "stbd list" with the lefty...
...compared to the "port list." Why not try the prop 1st, before going to the trouble of cable switching? Your shifter will simply work oppositely. If you get less list, you can always switch the cables later... ...but you may get more list! |
I had heard that 29 single fountians run a lefty is this correct and why? I am runnng a P5X 31 LH on my Baja single, lists to stbd, once on plane and trimmed out no problem.
Alot of 29 Fountains run LH props to correct the list.
On the Baja, you should run a RH prop. |
It is probably worth a shot. From what I hear some boats love it and some hate it.
I went to a LH prop on my X-18. It is a LH drive but that should not make too much difference if the boat is equally loaded right? In this case wrong. The boat loved it and loved it at all power settings. The change on the throttle took me about 30 minutes. I could probably do it in 15 now. I do have a Livorsi side throttle so yours will bee different but I don't see it being too hard. |
Originally Posted by bbladesprops
(Post 2653954)
On the Baja, you should run a RH prop. I got a deal on the P5X LH she does list to starboard at slower speeds (just like it did to port w/RH) but levels out at speed on plane. Randy |
It's at the shifter where you need to make the change. You can't change anything on the shift bracket to change rotation.
| All times are GMT -5. The time now is 08:37 PM. |
