Surface Drive Prop Rule
Is there any rule for a surface drive in terms of 200 rpm per pitch change. I am running 16 1/2 X 24 4 blades. At 0 trim or neutral trim i am @5700. The motors stop making power at 4900. I am going to try 30 pitch 3 blades. i have talked to a couple people on this and everyone said u gotta try them to figure it out. BTW 311 Formula KAAMA drive 1.54 trans 1.1 drive with 409 HP
OK prop tested sunday.
17x30 3 blade 63 @5200 anybody have any suggestions? |
The set up you got has 24% slip.
Something is wrong ?! I think 3 blades are not good for ya. $ blades in the right size is what you need. If your engines turn 5200 RPM ,with a 26 pitch prop and a 1:154 gear ratio the boat should run 73.2 MPH on GPS. That would be the ideal slip # . My guess is 18 X 26 4 blades ??????? Maybe 27's ??????? |
Originally Posted by daredevil
(Post 2657368)
daredevil, if you could, same basic deal but a little diff. 5400 rpm---1:54 trans gear ratio---18% overdrive/drive ratio and a 17x23 4-blade wheel, approx.speed ? thanks in advance ! ps: ya & 3-blades don't work well.
CORRECTION |
Originally Posted by I'CE
(Post 2717888)
daredevil, if you could, same basic deal but a little diff. 5400 rpm---1:154 trans gear ratio---18% overdrive/drive ratio and a 17x23 4-blade wheel, approx.speed ? thanks in advance ! ps: ya & 3-blades don't work well.
I've got an old Cigarette Flat Deck with Arneson Surface Drives, and the general rule of 200 rpms per inch of pitch applies but diameter, rake angle, and number of blades can't change also.
My boat tends to like bigger diameter, many blades, and high rake angles. Kris Vogt |
(Post 2657368)
Something is wrong ?! I think 3 blades are not good for ya. $ blades in the right size is what you need. If your engines turn 5200 RPM ,with a 26 pitch prop and a 1:154 gear ratio the boat should run 73.2 MPH on GPS. That would be the ideal slip # . My guess is 18 X 26 4 blades ??????? Maybe 27's ??????? 67.9 @4800 if i trim up all the way i think i can turn them 5100 BUT i also think it will prolly slip more. I am also thinking more diameter less pitch like a 18x 27 or 28 would be perfect!!! |
Originally Posted by Car Biz
(Post 2718264)
I forgot to post my new numbers but it seems still too much slip. 17 x 29 4 blades again at neutral trim.
67.9 @4800 if i trim up all the way i think i can turn them 5100 BUT i also think it will prolly slip more. I am also thinking more diameter less pitch like a 18x 27 or 28 would be perfect!!! I would also think a 18X28 , and go from there . But the slip # came down to 12% which is not bad at all ! |
slip
Originally Posted by RunninHotRacing158
(Post 2717902)
67.20 BIG Daddy :ernaehrung004:
| All times are GMT -5. The time now is 06:23 PM. |
