-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   px5 30 how bad on a bravo x drive (https://www.offshoreonly.com/forums/prop-talk/201517-px5-30-how-bad-bravo-x-drive.html)
AIR TIME 01-14-2009 09:56 PM
I talked to a few on baja site and they think the 30- 5 blade would be a lot worst than a b1 32 or 34, hp is high 3600 to 4000lb 24ft boat motor is going to be about a 1000hp, drive has tower, heavy cap and may get 11/4 prop shaft. so would I be nuts going with the px5 30 labbed, or should I stick with the 4 blade, I was told it would tq over the hull and flip it, and just destory the drive even if I don't nail it while on plane. anyone else run any think like this. thanks
Griff 01-15-2009 01:51 AM
I highly doubt that would happen. Either way, I think 1000hp in a 24 OL is a death wish. The boat was never designed to go that fast and is way beyond the limits of the hull.
Nordicflame 01-15-2009 08:04 AM
My buddy has a ThrottleUp tuned 30 P5X (actually I think he is selling it) and it was pushed by 1000hp in 4600 lb boat and it did done of the spooky stuff you mentioned :eek:
Actually ran smooth as silk and didn't do any torque rolling at all at appx 100mph. Max Machine drive held up well with it. Actually broke teeth twice with a Bravo 32.
There's actually several guys over on the Nordic section running these with big power.
Dave
AIR TIME 01-15-2009 12:39 PM
Dave
yes I read that thanks I thought a 30 would be just right but a 32 or 34 5 blade would be a killer., ah I am the guy buying it and a few told me not to well ch ging in the mail :ernaehrung004:
AIR TIME 01-15-2009 12:45 PM
on other sites theres close to 10 ols24s that run high 90s to 108, I've talked to owners the boat is more of a chinewalker in the 76 to mid 80s but calms down after and if set up like mine with full hyd steering, a shortie [stock drive height was to deep], the boat should be fine my ran mid 80s before with 380s k planes and add on stairing 2'' shortie . with my 670hp I did get some chinewalk at 78 , but did not have the full steering , for handling I leave my buddies 24 superboat 550hp in the dust in calm water or rough, and when I stuffed my boat back in 94 my hull did't separate like that 99 24 SB did on LI NY.. With a lili reinforcement those bajas do just fine we are making some changes to mine but with 36'' freeboard 8' beam 24 degree with a small 3'' pad its been good to me for 18years out in the ocean.
Beak Boater 01-15-2009 02:09 PM
Unless your prop slip is high, you will gain in the midrange and usually loose mph on the top end. You can pick up 4-6 mph in the midrange and loose 2-3 on the top end. Unless you are running 20% slip. They may also loosen up the stern by giving you more stern lift, which can make you chine walking worse. BBlades can work the 5 blades and help them out some. Give Brett a call be can help you more. Just sharing some personal experience.
Griff 01-16-2009 01:40 AM
Nothing against a 24 OL. I used to have one and it was a good boat. Outlawcowgirl owns it now. I just think that pretty much any 24'r with 1000hp and going 100mph is way beyond the safe limit of the hull.
AIR TIME 01-16-2009 03:15 AM
with the chine walk you see it more on the stern lifting props this is a px bow lifting prop if I get it if I get it it would be used for cruising and not wide open speeds I want a 32 or 34 b1 for that I figure I will run mostly 3500 to 4500 which or 50 to 75 for cruising.
KAAMA 01-16-2009 08:10 AM
I used to run 32" Bravo One 4-bladed props and since 2006 I now run the 30" P5X's (untouched) on Bravo XR's with 230hours no problems----perhaps only having a 32' boat and only 600+hp engines help keep things together.
I DO plan on removing the drives within the next month and have them inspected just for preventative maintenance. While we are in there we will install new bearings/races.
CNC 01-16-2009 08:35 AM
I ran a P5X 31 LH all season on my Baja (Sport 250, Procharged 1078hp) with a Bravo XZ modified by Mr. Gadgets (Dick). I loved it, great cruiser, best run 96mph. It tourqued a little getting on plane then was fine after that besides the evil handling over 90 (but I think that was just from pushing a hull designed for 55 to 60 to far. I am "gentle" getting on plane and don't apply full power until over 70. My Bravo 28 blew out all the time.
