30' chris cat props
86 chris cat
30' 900SC (dynoed 900 HP @ 5.5 boost) moved 2' forward #4 drives with merc. extension boxes (1.4 gears) boat weights about 8000lbs need help on props im hoping for about 130 mph :evilb:my need to turn up the boost. |
Originally Posted by cody_white83
(Post 2811755)
86 chris cat
30' 900SC (dynoed 900 HP @ 5.5 boost) moved 2' forward #4 drives with merc. extension boxes (1.4 gears) boat weights about 8000lbs need help on props im hoping for about 130 mph :evilb:my need to turn up the boost. Propwise i would start with a 4 blade 17-18 X 30-32 to see what she does. |
If you turn the engines at 6000, you'll need 36 inches of pitch. Test with 17"-17.5" diameter props in the largest pitch you can find. You need some type of base line to get started.
Brett |
| All times are GMT -5. The time now is 09:25 AM. |
