-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   '22 Wellcraft Scarab Prop Issues (https://www.offshoreonly.com/forums/prop-talk/205032-22-wellcraft-scarab-prop-issues.html)
chriseldridge 03-17-2009 09:47 AM
Hey
I am a new owner of a '22 Wellcraft Scarab. It has a 454 with a Bravo outdrive. It has a 26 pitch 3 blade prop on it, and in my opinion is way to high pitched for this boat. It cavitates out of the whole and I really have to work with it to plane it out.... What are your thoughts on a prop for me??
Thanks!
Chris
fastscarab22 03-17-2009 03:01 PM
if it has stock power , 23 pitch mirage, or 25 mirage will work great and jump on plane scott
1BIGJIM 03-17-2009 03:18 PM
I would try a 23 mirage plus. Yes a 26 is why to big for stock power.
chriseldridge 03-17-2009 08:36 PM
Thank you!! I was guessing a 22 or 23 myself.... What kind of hole shot can i expect? FYI the 454 has aluminum heads and has roller rockers on it.... Not sure if this makes a HUGE difference or not.... What are your thoughts???
Thanks!
CE
bbladesprops 03-20-2009 12:28 PM
You need to know where you want to turn the engine at WOT. Also the current WOT rpm #.
Then determine your performance goals. We have test propellers for loan if you would like to try some.
B
fireboatpilot 04-02-2009 11:10 PM
24' Checkmate, 454, bravo, mild mods done. 23P for sking/tubing, 25P for speed, 65mph at 4800rpm.
