TRS prop question
Ok guys I have a TRS drive with a 21pitch Quicksilver Mirage 3 blade prop on my boat. I heard the Bravo 1 props fit TRS drives..is this true? Also is there anything I need to look out for when changing pitch. I need to go up atleast 2 pitchs on a 3 blade or possible only 1 pitch up on a 4 blade prop since my 330hp 454 is spinning to 5,500 rpm's which is way to much. While I have you guys here what is the pro's and con's of a 3blade and 4 blade prop.
Erik |
I would try a 24P bravo one prop to get you back down to the 4600RPM range where i think your 330 need to be. Or maybe a 25P mirage.
Originally Posted by MILD THUNDER
(Post 2872878)
Erik |
Originally Posted by crapr6
(Post 2872894)
I should have posted that the 330hp 454 does have lighting headers, and performer intake. I know its not a big gain in HP and I know this motor has cast rotating assembly but does this motor only need to turn at 4600rpm's?
Erik |
So does a bravo 1 prop fit a TRS drive?
(Post 2873285)
Originally Posted by lost2a6
(Post 2887388)
Yes, I have one on my TRS. I lost about 1.5 MPH on top end compared to my Mirage, however my cruise picked up 1.5-2MPH along with several other benefits. :drink:
What kinda speeds are you seeing with your set up ??
Originally Posted by myscarab30
(Post 2887562)
Erik |
you didn't say what hull...
but I agree with a 25 Mirage or Mirage + |
| All times are GMT -5. The time now is 03:53 PM. |
