-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Need prop recommendation for 30' Baja Outlaw (https://www.offshoreonly.com/forums/prop-talk/209542-need-prop-recommendation-30-baja-outlaw.html)
Ready2roll 05-25-2009 11:19 PM
My boat is stock with twin 496HO's.
Any recommendations would be appreciated.
Plum_Crazy 05-26-2009 12:48 PM
I would think Bravo 28's would be correct.
RichieD 05-26-2009 03:20 PM
what, on it now
Ready2roll 05-26-2009 04:11 PM
It's got the stock 28's on it.
I did some reading and someone mentioned "labbed" 28's?
indywhsle 05-26-2009 08:41 PM
I would think you would want to see where you rpms are WOT. If they are too low from the recommended rpms then labbing the 28's would seem like the thing to do. I the rmps are where they are supposed to be then it may not be worth labbing them because you may just end up banging the rev limiter. You should be able to count on increasing rpms by at least 200 rpm after labbing but I am no expert. Just learning as I go.
crayolacrazy 05-26-2009 08:50 PM
30 labbed it will do 78-79
Ready2roll 05-27-2009 08:26 AM
My RPM's right now are only 4600
So if i lab the 28's i should be at 4850 +/-
Wouldn't labbed 30's bring the RPM's down too much on my boat?
310DETAILNOW.COM 05-27-2009 10:15 AM
:ban: if you drop down 1 prop size it should make the boat faster but thats something you would have to test drive to really see.
Plum_Crazy 05-27-2009 11:07 AM
In that case, yes to labbed 28's or stock 26's. However, your RPM's seem low. What speed are you getting?
Ready2roll 05-27-2009 01:41 PM
with 1/2 tank of fuel and 4 people in the boat i pulled 73.9 on GPS in flat water at 4600-4700 RPM.
Looking for 80 with low fuel and 2 people :)
indywhsle 05-27-2009 01:47 PM
Also keep in mind that it is only going to get warmer and your motors will likely not make as much power. I am propping mine for the summer heat. I started out thinking I would need 34p labbed bravos and am now going with cut down 32p bravos just to be able to turn the right rpm.
Ran-Dom 32 05-27-2009 08:28 PM
good luck gaining 6mph on a prop change:lolhit:
1-2 would be realistic
Westcoast 05-27-2009 08:34 PM
Are you trimming the boat correctly? Those engines should be turning 5000rpm
indywhsle 05-27-2009 08:38 PM
I don't dought it. I was only able to get 4900 out of mine down at cumberland. They spun 5300 when it was cooler out.
Ready2roll 05-27-2009 09:32 PM
Yes, trimmed it many different ways until i found the sweet spot.
It's very hot and humid down here in the swamps of Louisiana so I'm sure that's part of the reason for the low RPM's.
Just ordered a pair of Labbed 28's from BBlades. Will let you guys know how it turns out.
Westcoast 05-27-2009 10:13 PM
I'm sure you will be happy with Bretts props. The engines will be much happier :boat:
Irishtornado 07-12-2009 12:59 PM
This seems very low for HO's what is the temps you are getting this at? Send the props to Bblades and have them labbed and cupped you should see drastic improvements...I'm able to spin 30p labbed from Bblades at 4700rpm's in cool temps running 77-78mph on GPS with HO's in a 302
Anchorman 07-12-2009 08:03 PM
A buddy of mine has an 07 with HO's in Florida and spins 28's non labbed at 5000-5100 when it is in the 80's and 4900-5000 when its in the 90's. He sees 76-78 max on inland lakes Fresh water. He tried to spin my labbed 30 but I had them set up differnt than what his boat likes. I ran with a Faja 30 today and he had 4 people and 1/4 tank as was running 75-76. Try labbed 28's and get them set to your boat. I would recommend BBLades. Get him RPM and GPS speed numbers and it will help him get the right set up you want. He nailed it on my boat.
Busta 07-15-2009 12:44 PM
In the cooler months, I can run labbed 30's and tap the rev limiter (usually about 78mph but have hit 80 one time). Right now, I'm only seeing about 4500-4600 rpms so I think it's time to throw my labbed 28's back on.
sidetracked502 08-16-2009 08:24 AM
well how do the labbed 28's work?
