-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Maximus vs. Bravo prop (https://www.offshoreonly.com/forums/prop-talk/215073-maximus-vs-bravo-prop.html)
mapism 08-17-2009 11:26 AM
I already started this discussion while drifting a bit from this other thread, but Prop Talk is surely a more appropriate place for this subject.
My stock Fountain 27', with a 496 HO and Bravo 26" prop achieves 69 mph at 5100 rpm if very lightly loaded.
Which is ok, but the boat is a real pain to get on plane, particularly when loaded.
According to what I read, the Maximus with its 5 blades and the PVS should give much better results in this respect, but I'd really like to hear the opinion of some prop wizard.
I see that there are some around here... :readinghelp:
bbladesprops 08-18-2009 12:00 PM
Your boat would respond very well with the Maximus propeller. It would be best suited if Labbed to meet the boats needs. This would include a diameter reduction. Because your slip number is not real low, the 5 blade may even increase the top end with Labbing.
We have the stock props for testing if your interested, as well as some Turbo and Hydromotive 5 blades.
Brett
mapism 08-19-2009 02:18 AM
Thanks Brett, pm sent.
