Maximus or P5x? Best bow lift?
Which of these two props has the most bow lift (least stern lift)?
A 15".. short tube.. Maximus or A P5x The boat is a Nordic Heat (28ft, single engine, v-hull) Prop shaft is at 3.5" below the keel, with a stepped hull, and a notched transom. Current speed is 92-93 mph. Speed with new motor should be over 100 mph. Chris |
Originally Posted by CB-BLR
(Post 3071444)
Depends on the full Max recipe.
We can create way more bow lift with a 15" Max with the diff. removed than with the P5X. However, the P5X in stock form has more bow lift than the stock Maximus. Brett |
| All times are GMT -5. The time now is 03:39 AM. |
