496 Ho Prop Question????
I have a 35 Fountain executioner with 496 HO'S and running 32p bravo 4 blade props.. I have a set of Herring 5 blade 32p and want to know what it will do???? My boat runs around 75 or a little more at 5400 rpm's.. Will these props benefit me???
5400 rpm at wot?
I think rpm range on a 496HO 4600 to 5000rpm |
The 5 blades will pull the rpms down and increase the stern lift in the boat. You will probably see better cruise speeds.
The rev limiter for your engines should be 5150. Brett |
| All times are GMT -5. The time now is 03:25 PM. |
