-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   prop shaft wobble (https://www.offshoreonly.com/forums/prop-talk/230971-prop-shaft-wobble.html)
rssteiny 05-21-2010 07:28 AM
prop shaft wobble
fired up motors yesterday and put drive in gear and notoced with no props on the shaft on the one drive has a slight wobble to it and the other one spins perfect never noticed it before and both lowers have been done in past 2 years, will it hurt to run it. It is maybe out 30 thousands but it is tight coming out of the case so it must be very slighlty bent.
mudslide 05-21-2010 08:02 AM
It sounds like the shaft is starting to break. You should change it before your prop will be on the bottom of the lake. Just broke one this pass weekend a luckily caught it before I lost my prop.
MILD THUNDER 05-21-2010 09:11 AM
Even if the shaft didnt break completely off, the harmonics i would think would take their toll on the internals...
t500hps 05-21-2010 09:42 AM
If you can SEE a wobble, it's bad. It will quickly tear up the seal and loose drive fluid and allow water in the drive. Then your replacing an entire lower/drive instead of a prop shaft.....your call.
RT930turbo 05-21-2010 11:01 AM
Agree, if you can see it, or feel it; replace it. Much less of a headache to get it over with now before you loose a prop, smoke a drive, and ruin a day on the water.
rssteiny 05-21-2010 03:57 PM
how hard is it to change a prop shaft, and do you need special tools.
t500hps 05-21-2010 04:49 PM
If your asking the question......you need to pay someone to do it. The tools alone cost 2-3 times what you'll pay someone. and assuming you do it right and don't tear up a lower from putting it together wrong you could be WAY ahead by paying the labor.
