-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   mirage plus vs. laser II (https://www.offshoreonly.com/forums/prop-talk/233235-mirage-plus-vs-laser-ii.html)
87MagnumII 06-22-2010 07:46 PM
ok, i have been to mercs site and read the specs on the laser II and the mirage. i currently have a laser and am considering switching to a mirage to get more lift and a little more top end. merc says the laser gets more lift but i was told by a friend to try a mirage anybody have any real life experience with these two props?
bbladesprops 06-22-2010 09:29 PM
Tons, as well as many folks on this site.
Let us know your set up and performance numbers and we'll all try to help.
In a nut shell, the M+ is better suited for larger boats with more HP than the boats the Laser 2 would run on.
Call us if you wish to dicuss specific information.
Brett
rchevelle71 06-23-2010 09:09 AM
What size were you considering, I have a few Mirage and Mirage plus, that I may consider trading one for a Laser.
87MagnumII 06-23-2010 09:56 PM
i have a 21p laser looking for a 21p mirage, would like to try before trade if we could work it out
87MagnumII 06-23-2010 09:59 PM
Brett
its a 1987 concord magnum II www.concordboats.com
currently a 260hp 5.7L but i am in the process of building a new engine that should come in around 350-400hp. turning the 21p laser II at 4300 rpm aprox 53 mph at 3000ft above sea level
rchevelle71 06-24-2010 09:39 AM
I have a 21 Mirage Plus, and a standard 21 mirage, I would like to keep the standard, since it turns a few more RPM's on my boat(outboard). I wouldnt have a problem with you trying, if you paid the shipping(both ways if you decide to return).
wtfo 06-24-2010 04:22 PM
In my experience, if a laser has enough blade area to hold / doesn't slip too much, you'll lose speed going to a mirage plus... if you're cavitating the laser then a mirage will hook up better, but still probably not be faster on the top end. imho
