-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   need help identifying prop diameter (https://www.offshoreonly.com/forums/prop-talk/234333-need-help-identifying-prop-diameter.html)
87MagnumII 07-08-2010 06:56 PM
its a laser II 21p
prop numbers read like this:
EC quicksilver 48 16546 441 21p
any idea what the diameter is??
i ran a 15x19 solas ss three blade this weekend and it actually dropped 200 rpms and 4 mph from the laser II listed above
87MagnumII 07-14-2010 10:27 PM
bump
A.O. Razor 07-15-2010 05:00 AM
Laser II 21" is 13.875", so you are probably loosing speed due to the larger dia. If you think there is more to gain, you should try a Enertia 20" or a vensura 21". On some boats, the vensura has turned out to be 1-1.5 mph faster than the Laser II.
Denscarab 07-15-2010 08:48 PM
Prop help
I have a 86 scarab panther with 2 502's. With trs drives.. Can't figure out what size props to use keeps spinning.. Any help?
