-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   3 to 4 blade help (https://www.offshoreonly.com/forums/prop-talk/235713-3-4-blade-help.html)
doral1 07-28-2010 02:49 PM
3 to 4 blade help
I am running 3 Blade Bravo 27P props. I would like to go to 4 blade. What direction should I take???? Do you need to go up or down when going from 3 to 4 blade??? Thanks Chris
UrbanDisturbance 07-28-2010 03:27 PM
You have 3 Blade Bravo 27P.
You have to go down in pitch to keep the same RPM when adding 1 blade.
Try a 4 Blade 25 pitch to regain your possible 400rpm loss.
You can loose up to 400rpm by adding one blade and keeping the same pitch.
Every pitch you decrease will increase your rpm 150-200rpm.
I lost 400rpm by going from a 4 blade to a 5.
zx14k 07-28-2010 07:50 PM
here my numbers=GPS and smartcraft digital rpm.best
mirage+ 23 66.4 at 5050
bravo1 22 64.5 at 5150 hit the rev limiter.
but i realy dont know nothing about a bravo 3 blade???
onesickpantera 07-28-2010 09:22 PM
There is no Bravo 3 blade. A Bravo 24 would probably be your best bet as it's actually closer to a 23. It will probably run 4800 give or take. There's lots of other 4-blade props out there.
Is there a reason you want to switch to a 4-blade?
goebel1 07-28-2010 09:27 PM
I have a mercury lab 24 for sale
http://www.offshoreonly.com/forums/s...egt-setup.html
