Griff: The porpoise does seem less with a little chop. That rpm situation is what is most confusing to me also, but I guess the more slip % is letting the r's go higher?
Michigan troll: I have a BBC 489ci, carb, w/ a retro roller setup making around 500hp. Did that setup make a rooster tail? |
Sounds like your over trimming the 28 or it has been cut down quite a bit.
Ours throws a big tail from 8 foot full out to about 12 foot at 3/4 throttle. I trim +3 of neutral maybe a little more for full out. But our is a drivers boat. You play with trim and tabs at all speeds to keep it level. They need 1 foot of chop or more for full speed and less tab. When I purchased the boat it had a 28 Bravo. I pulled the spacer and I had a hard time getting on plane and could not run over 65 without blowing out the prop. The 28 Max fixed everything and now will have it tuned and labbed. |
Prop is 15" dia. Im only trimmed maybe +3 from N also. I have it trimmed for max speed and with the porpoise, it is loose!
Michigan troll, what power do you have? |
Ours dynoed 814hp @5500 and 810T @4700. Currently running a stock 28 Maxximus. You should be able to turn a 24-26 Max.
| All times are GMT -5. The time now is 09:16 AM. |
