Hydromotive QIV vs QIV-X >
Old 09-17-2010 | 09:41 AM
Default Hydromotive QIV vs QIV-X
I have a QIV-X & was thinking of trying a QIV in the same pitch. Looking to lower slip & slightly drop RPMs (50-100rpms). Anyone have experience comparing the two?
Itsallgood995 is offline
Old 09-17-2010 | 12:17 PM
They are completely different props. It depends on your boat as to which one is better for it.
Griff is offline
Old 09-17-2010 | 04:49 PM
tmdog's Avatar
Call Hydromotive, they are very helpful.
tmdog is offline
Old 09-18-2010 | 11:31 AM
CB-BLR's Avatar
Chris
The Q4 is a semi cleaver style... and is a stern lifting prop.
The Q4x is very very similar to a Bravo prop, but is 15" in diameter, and available in 1" pitch increments.
Chris
CB-BLR is offline
Old 09-30-2010 | 08:04 PM
read hydro or bravo thread
KEVLARKAT32 is offline
Old 10-01-2010 | 01:36 PM
Chris
Any guess on what the rpm drop would be?
Old 10-01-2010 | 06:23 PM
CB-BLR's Avatar
Chris
In my experience... a 28 Q4x only spun about 50 rpm more than a stock 28 Bravo. The Q4x was faster on my boat by about 2-3 mph. I run a 1.34 gear ratio.
Chris
CB-BLR is offline
Old 10-04-2010 | 07:27 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Q4 is 15.5" in diameter.
The Q4X is 15" propeller copy of the Bravo 1.
High X dimention boats with natural bow lift can benefit from the Q4. Boats needing more reaction to trim are better off with the Q4X.
Brett
[email protected]
bbladesprops is offline
Old 10-05-2010 | 10:50 AM
Brett
My boat has huge afterpods molded into the hull that extend 28” past the transom. As a result the pods drag w/ bow lifting props. Do you feel the stern lifting QIV would be worth a try or is there something I’m missing? The drive is deep (8.5”)
Old 10-05-2010 | 07:45 PM
Smile
Maybe..................
There are a lot of unknowns here.
Just a couple would be, what boat do you own and what power is in it? LOL
It seems folks do have answers though.
This sounds similar to a application we/BBLADES started to talk with earlier this year.
Tell us more or give us a call.
Brett
[email protected]
