looking for right prop for volvo 280 outdrive, need help!
i have a 1978 24' P&D with a 351W motor the was recently rebuilt and with a 280 volvo outdrive with a 15x21 RH turning prop. MY mph is about 4 under whatever my rpms are (ex: 4000 rpms and im running about 36 or 37 mph.) I was told to put a 16x23 prop so it will at least match up. Any advice on where i can find one or what size i should go with?
Prop
Originally Posted by zavier24
(Post 3241478)
Originally Posted by Throttle Fever
(Post 3241782)
I had a old (87' Sleekcraft) 30' with twin 425 hp smallblocks. Ran some rehub Mirages 25 pitch with the defuser ring cut off. Also was running hydromotive nose cones on them with a 1.5" trimmed of the skag. Boat ran 76 mph. So thats what worked with my 280's. The 16" I think would be to big. What rpm's do you want to run at?
I have the old style simple outdrive, is that what you had? I would like my cruising speed to be at about 3800-4200 rpms but i want to get the most mph possible. My motor is pushing about 375hp so thats why i was told that the 16 would be ok. |
Drive and prop
(Post 3242238)
If you have already experienced it then thats what I wanted to hear, the results that someone got with those props. So you got a5mph more with the Mirage props? Where did you get the Mirage style props at?
I would try to find a good local prop shop, and see if they would let you test some sets. Volvo performance props for those drives are a rare thing. So rehubing some Mercury props are a option. It can get expensive prop testing, being rehubing is the only option. My "guess" would be to start with a 21 pitch and test from there. I spent two seasons testing props on that boat. With out knowing your boat, set up it is a gamble. Good luck it can be tireless..Pete
i think that is what i might just do then, thanks alot for your input
| All times are GMT -5. The time now is 12:21 PM. |
