312 fastech prop help/nose cones?
I'm turning 30'p Bravo-1's that I had labbed?????? I'm getting 72 at 5100-5200 rpms on twin 454mag mpi's 1.65 gears,, seem's like my slip is still high,, Would nose cones help with this Fastech hull. The cruise seems good..
Seems like if I could lower the slip I could raise the speed 3-4mph...:drink: |
I had the same boat with 502 mags.......74 GPS was all I could get out of it. (on a good day)
I put a Hydra-Motive cone on my Bravo last season. It was the best thing I could have done. I run low to mid 80's in a Velocity 280. The stability at the upper range and low speed handling is worth it alone. I haven't been able to do any real speed testing yet, although I was able to hit 82 with three more people in the boat.
I have a 2001 312 Fastech with 454 Mags too. I can only get 4,500 RPMs at WOT. Is 1.65 stock?
Thanks. |
Originally Posted by mdegeneffe
(Post 3478245)
Thanks. |
I guess I'll have the tech check when I winterize. What gear ratio/prop combo is best? Also, the props look ok... they are Bravo I props with no visible damage. What should I look for to determine if they are F'ed up?
(Post 3478341)
(Post 3478341)
(Post 3478245)
Thanks. I do have off shore exhaust and took off the silent thunder, also vortech breather. |
Originally Posted by silent lucidity
(Post 3326568)
| All times are GMT -5. The time now is 03:46 AM. |
