-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Need prop advice for my crownline (https://www.offshoreonly.com/forums/prop-talk/252127-need-prop-advice-my-crownline.html)
donzi matt 04-24-2011 07:15 PM
I recently made some motor changes to my 1993 Crownline 225 bow rider with a 350 mag and Alpha 1 gen 2 with a 1.47 ratio. I am estimating between 320-340 hp now. I raised my WOT RPM by about 600 RPM's to 5000, which is ideal, but it takes quite a while to get there. The boat still doesn't accelerate as well as I would like. It currently has a 3 blade stainless, with no markings to indicate size. Running through a prop calculator, and ASSUMING a 20% slip at WOT, it works out that it is a 21 pitch prop. I suspect it is a rebuilt propeller of some sort. This prop came on the boat but was not the original, but swapped on as part of the deal with the marina, so I know it is not what came from Crownline, but what achieved RPM that the marina had in stock. In short, it is sort of a mystery prop to me.
I am considering going to a 4 blade to help with the holeshot, but I am really hoping an optimized prop will not sacrifice top end. The boat feels like it runs wet, and I can't seem to trim it out enough to lift the bow with the current prop. I am hoping for some suggestions on what will work well. It is a pretty wide, heavy boat, and truth be told it would probably be more well suited with a big block and a bravo, but this is what I have to work with. Some suggestions would be great, as this is total black magic to me. Thanks in advance for any advice!
The specs right now are:
350 with vortec heads, comp xm-270-hr cam, holley 600 double pumper carb, silent choice open.
4900-5000 RPM
54mph GPS steady at that RPM, light chop
johnfharding 04-24-2011 10:11 PM
My opinion
I would go with a 19 p. Rev4 in a four blade to start with. I think your boat is fairly heavy and the one I was in with the same set up I think was running a 21p Mirage. Good boat really nice and a Sharp looked all fire engine red with white interior. Try to find someone with a known prop model and pitch and post back with load , weather , conditions and some rpm and speed numbers and these guys will be able to help more . At this point we are all going to be shooting in the dark.
bobl 04-25-2011 03:14 PM
I've set up quite a few 225 Crownlines. With the Alpha drive the Rev 4 is a bit large in diameter. I'd run something like the Merc Vensura series in a 4 blade. The Vengence works good in a 3 blade. Also the Michigan Ballistic performs very well on that boat. Probably end up with a 19" pitch. Speed in the mid 50's sounds about right for your setup.
Bob Lloyd
Full Throttle Marine
A.O. Razor 04-26-2011 01:29 PM
Bob Lloyd
Sorry for the hijack.
Bob
I've never seen the Vengance as a performance prop. What makes the Crownline and the Vengance work so well together? I've always seen, and used Mirages/M+ and LaserII's in similar 3 blade applications, but haven't had much luck with the Vengance(the few times I've tried). Why not the LaserII and M+ on the Crownline? Just curious.
Ps. I have been in a 19' and 21' boat with the Vensura. That is a nice four blade for sure. A surprisingly fast four blade.
bbladesprops 04-26-2011 07:51 PM
I just thought I'd through out some history.
Vensura was the original large hub Trophy (pre Plus).... Remember that? Boy do I.............. and the repercussions.
Then it was the ? Who can answer that question?
Now it is the Vensura.
I'll tell you more if you can get the second question correct.
The Vengeance is a nicely named QS thicker with HiPolish finish.
I kind of like the Rev4 too (depending on your goals). Down pitch to get your engine to the top of the R range for the engine. This will not hurt the drive and give the boat all around performance.
Brett
A.O. Razor 04-29-2011 05:53 AM
Brett
That was called the Offshore. Sometimes the Vensura is still called the Offshore series. What do I get:party-smiley-004:
Racerryan 04-29-2011 09:05 PM
Hi guys: Just giving some background info on the setup we have on our hammer. Hopefully it will give you some help on selecting a prop.
'21, 3700lbs, 454mag mpi, 1.5 gear
original on boat 23" mirage plus 70mph on rev limiter (5150rpm I think) very good hole shot, bad cruise rpm.
bravo 1 24" stock, 68mph @ 4900rpm, good hole shot, very good cruise rpm and very smooth, never slipped.
bravo 1 24" labbed, 70mph @ 5100rpm, good hole shot, good cruise rpm and very smooth, some slip if trimmed up too much.
25" mirage plus, 70mph @ 4700rpm, slow hole shot, very very good cruise rpm, no slip.
25" mirage plus labbed, 72mph @ 4900rpm, not to bad hole shot, very good cruise rpm, some slip if trimmed up too much.
slip numbers were always between 6% and 9%. I do not think that your slip would be anywhere near 20%.
with the mirage plus props they also have the vent holes that help getting out of the water. I would start with a 19" mirage plus and take it from there. b blades can add or remove cup depending on whats happing with the boat. Good Luck!
donzi matt 05-01-2011 07:43 AM
So I went and tried the Rev 4 19 pitch, and frankly I wasn't terribly impressed in my particular application. The prop bites hard for sure, but right out of the hole the boat lugs a bit till about 2000 RPM and then it pulls well. The holeshot was better, but not by much over my current 3 blade (which I confirmed is a Stiletto 21 pitch). I think a couple of things are at play here. One, the slip of my 3 blade gets the boat to build some revs out of the hole. And two, the hard bite of the Rev 4 keeps the motor from getting into the sweet spot of the cam, around 2000 up.
I didn't try with the vent plugs out, but I am not sure they would do me much good since I have through hull exhaust. I lost 2 mph also. I don't mind giving up 2 mph, but I want better acceleration if I do.
It wasn't all bad, the prop was very smooth, the midrange hit was awesome, and the boat cornered better than ever. I also pulled 4900-5000 RPM's with 2 people in the boat and 1/2 a tank of gas, so the pitch was right on. I was just hoping the boat would get out of the water better, and that is what I need to justify spending 500+ on a prop. At this point I think I am going to call Brett at BBlades and see what they think would work well as I am not sure an off the shelf prop is going to give me what I want.
Just to clarify some gray area, I am currently running a 21 pitch Stiletto. The boat pulls 54 mph GPS at 5000 RPM on a 1.47 ratio Alpha. This was with 1/3 tank of gas (20 gallons), one person, moderate chop, about 50 degrees ambient temperature with exhaust open. Running the numbers through a prop slip calculator, I am getting 20% slip.
johnfharding 05-01-2011 10:27 PM
Question or two.
With regard to the plugs, if you have captains call I would think some exhaust is likely to still be routing through the propeller even with the thru-hull turned on. So you might go ahead and open them up all the way and see if it helps get you into the sweet spot.
Smaller diameter 4 blade vensura prop like one of the previous posters mentioned might help the RPMS come up quicker, and keep some of the mid range punch. BBlades labbing the Rev 4's may make it easier to turn them up, but would probably add RPMS up top, and you don't need that.
Thinking outside of the prop.:-)
Just a couple questions on your engine. The cam shaft is as big as you can go which would sacrifice off idle grunt up to the 2000 rpm you were talking about. This combined with the heavy boat are working against you in this application. So outside of going down some on cam size which is probably not an option. Is the carb working o.k.? Just wondered as it might be causing some off idle laziness issues as well. I guess I'm thinking along the lines of maybe its running lean, or the accelerator pumps aren't shooting enought fuel so its bogging a bit. Also is the timing set to factory specs? Also from what I have read on dyno tests for the Vortec heads, the overall timing should be no more than 34 degrees total. Just some ideas.
bbladesprops 05-02-2011 05:17 PM
A.O. Razor,
Nice job! Call me and we'll send you a BBLADES t-shirt.
Brett
donzi matt 05-02-2011 05:21 PM
Thanks for the input John! I spoke with Brett at BBlades and he is sending me a Rev 4 to try without the plugs. His thought is even if I have no exhaust through the hub, the negative pressure at take off will still pull air and possibly give me the results I am looking for. He feels the Rev 4 is probably the best bet for the boat, and if need be labbing could be done to increase performance without changing top RPM.
As for the motor, I am running a 600CFM holley. The motor feels like it is pulling fine, and I have brought the jetting on the primaries from 67's to 69's with no change off the line. I have 70's I may try also, but if those don't change anything than I think I can rule out the carb. The motor feels just fine, with no lean sags or stumbles to it. I do think the cam is on the big side though. I chose it because I was afraid the larger torque on the XM-264 would be more likely to hurt the Alpha than the XM-270's torque which occurs a little higher up the powerband. I have total timing set for 30 degrees at full advance, as suggested by BobL.
I think a little slippage might help get me up into the best spot in the powerband, and make the boat feel totally different on launch.
A.O. Razor 05-03-2011 06:33 AM
Brett
Brett
We need updates on this:lolhit:
bbladesprops 05-03-2011 09:44 AM
Not sure what you mean. Look back3 posts.
Brett
By the way, it isn't supposed to be refered to as the OS series any more. Merc likes the new marketing aspect as being a fresh item..........
A.O. Razor 05-03-2011 02:11 PM
Brett
Oops, missed that one! Sorry.
Will do. Thanks:coolcowboy:
I think my reference to the OS series, is just a force of habbit thing. I would NEVER do something like that deliberatly:D
Sent you a pm.
hallj 05-03-2011 03:33 PM
Try a vacuum gauge on the intake manifold. I'm guessing at WOT you'll find your carb is too small.
Jeff
donzi matt 05-03-2011 08:14 PM
You think? Every CFM calculator I could find told me a 350 running at 100% VE (which I surely am not close to) at 5200 RPM only requires around 530 CFM. Unless I am missing something, I think I should be ok on CFM, but I will do a vacuum check for giggles.
