-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   best prop for 22' hammer with mild mods? (https://www.offshoreonly.com/forums/prop-talk/253989-best-prop-22-hammer-mild-mods.html)
BajaBeckley48 05-20-2011 03:09 AM
Got A Carbed 7.4 Ltr In 97 Baja Hammer Thinkn Of Doin Bigger Carb/ Intake An Possibly Msd Ignition To Free Up Sum Exsisting Power/ Create Around 200-400 More Rpms Or So? Running A Nice Surface Peircing Prop That Runs Around 70 Completely Empty.. Wonderin What Would Work Best Maybe For Parts/ Pitch Prop To Get The Most Top Speed Possible With The Mild Bolt Ons? Any Info Would Help.. Thanx A Lot!
Dave M 05-20-2011 06:50 AM
I'm suprised that a "surface piercing prop" would work well on that boat. Bajas usually have conservative drive heights. My guess would be a Mirage +.
THE 288 KID 05-20-2011 11:15 AM
You made it onto oso finally! Welcome BUTTERCUP BECKLEY
bbladesprops 05-20-2011 05:19 PM
There are options. Your current prop model and the actual performance numbers will help make the decision.
Brett
BajaBeckley48 05-21-2011 02:19 AM
Numbers completely stock and empty are about 67-68 @4800 rpms .. with carb,intake an ignition wondering if anyone's had a 25 or 26p on there maybe with a 454 mag?/ numbers it ran?
AJ POWERPLAY 05-23-2011 05:43 AM
Beckley- here is your best option, replace the boat not the prop :lolhit: you need a bigger boat for all your babes!
bbladesprops 05-23-2011 08:52 PM
I don't know what a numbers completely stock propeller is.
When you want to get specific... We're here.
Brett
blownhammer2000 05-23-2011 10:06 PM
i'm guessing you have the mirage plus 23p, had that on my hammer and best i got was 66 maybe 67, added dana marine exhaust and changed to a mirage plus 25p and ran consistent 68 and occasionally a 70 in perfect conditions, exhaust freed up some rpm and could swing the 25p at 4600, 4800 is the top of your rpm band so you could come down alittle
Racerryan 06-08-2011 11:36 PM
Our hammer runs 70 with labbed 24bravo and 72 with labbed 25mirage +. This is with a 454mag mpi box stock and in best conditions.
