-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   what prop for 261 liberator with single engine? (https://www.offshoreonly.com/forums/prop-talk/255613-what-prop-261-liberator-single-engine.html)
S.Y. 06-11-2011 09:13 AM
Hello im new here. Recently bought a 88 liberator 261with with a single 460. Motor has a holley carb and edlebrock intake. I believe it has the wrong prop on it. Its a 15x17. It gets on plane real quick but revs out at 4900. No gps in the boat yet but phone gps is saying around 40mph. I did some searches but couldn't find anything specific. Im thinking around a 21 pitch. Any help on this or where I could find help would be appreciated. Thanks!
Racerryan 06-12-2011 12:24 AM
If that prop is a 15" diameter and 17" pitch then it's unlikely that the boat will pull a 21". Maybe try a 19". Stick with a 3 blade on that boat it will be faster then a 4.
Airpacker 06-12-2011 07:45 AM
if its only pulling a 17 to 4900, I would want to know why.
S.Y. 06-12-2011 12:06 PM
I spoke with a few others and a 19 or 20 seems to be what I need to try.
FIXX 06-14-2011 11:36 PM
Fixx
if you have a cobra drive i have done alot of prop testing on a 211, same power but more hp then stock power..the boat loved a mach 1 4 blade the most..the prop we ended up with was a 16x20 and would top out in the high 60's..its just a heavy boat..
