Increase/deacrease prop pitch ?
I have a brand new Bravo1 22p lab.
The thing is that it's to small and I need 24p lab. Is it possible to bend it up to 24p? I don't want to bend it if a standard 24p lab will give me better performance. I have a Rev4 lab that I added cup ,but now I can't turn it and it does not grip as good as my Bravo1. Can I decrease the pitch on my Rev4 and still make it as good as a new one? Let's say my is a 25p lab with extra cup,maybe it's 26p now. Can I bend it back to a 24p with extra cup without taking the diameter? I'm trying to find the best prop for my Airshiprib/Cougar R8 with Mercury Verado 350SCI. Now I have 5 props that don't fit ,and props are expensive and hard to get in Norway. The Bravo1 made it more stable,better grip and better seakeeping,but I think I need to do something when I get the right pitch to lift it more out of the water to get max speed. It's fun to get 7000rpm in about 10sec,but missing 8 mph :-) |
your Rev 4 is a 25P w/ cup added? I have a 25P b1 (re pitched) if your interested?
You can only change actual pitch by 1". I would not make more major chnages to your props. It will weaken the blades.
Call BBlades and get some test props. |
Thank you Griff.
Then I know I have to buy one more prop. I talked to Bret last year and we decided that it's better to make my prop here in Norway/Scandinavia because of the shipping. But my problem is that my props are to far from the right size to start working on. I will order a Bravo1 25p lab and I will go from there. I understand now that a 25p Bravo1 is actually a 24 pitch. Does anybody know the best Rpm a Verado 350SCi shall run on at highest possible speed with one person low fuel/weight It stops at 7000rpm,but a guess it's not much torque at that Rpm so a have to increase the pitch up so I can get the rpm down where I get best rpm/pitch/speed,but how low? I have heard everything from 5600-6800rpm. It's 300rpm/pitch but it's not easy to know what size to start with. 24,25 or 26P? That's the problem when a prop cost 2600$ here and no return. |
The recomended rpm range is 6200-6800.
| All times are GMT -5. The time now is 02:37 AM. |
