difference between a bravo 1 and a quicksilver
Have a 27 Kryptonite w a 28p bravo 1, 1.50:1, and a merc 500efi w the Arizona speed and marine flash. Only seeing about 5000 rpms and 72 on gps. The boat supposedly ran 81.2 WITHOUT the ASM flash and a quicksilver 14 3/4x28 @ 5250. Ideas? Thoughts? The boat pops on plane effortlessly.
What QS propeller?
Your slip is a touch high. Brett |
Brett, all i know is The boat supposedly ran 81.2 stock "without" the Arizona Speed n Marine flash and a quicksilver 14 3/4x28 @ 5250. Now im running it with whats labled a 28P bravo 1 and only seeing 5000 rpms and 72mph...what are your suggestions.
Your slip is about 16.5%. A touch high. (the Lab recipe could be off)
The slip would be 6% lower with the other numbers and the fact that the engine was able to pull higher R's with a tighter prop also amplifies the weirdness. Either not as much HP now, something else has changed on the boat or............."supposedly ran" isn't fact. Brett |
Brett, what do you recommend we do from here.
Sorry Bernie for not calling.
I'll try to get ahold of you tomorrow. Brett |
| All times are GMT -5. The time now is 09:59 PM. |
