Props will not Fit??
Hi, I purchased a couple of 30 p bravo 1 4 blade labbed props for my 2007 32' Sunsation with bravo I x drives. The same that it came with but labbed. I cannot slide the one piece hub onto the shaft:eek: Part number showing on the hub is 840237-C. Fits nice in the props but a no go on the shaft splines don't seem to match up. Any help would be greatly appreciated:confused:
You should be able to take the inserts out of your old props and use them. I know the XR uses a different insert than a standard bravo. Not sure about the bravo x.
Originally Posted by campionchase910
(Post 3479724)
Thanks Dave M and Craper6. I just used the hubs out of my other 30's and no issues. Part # for the hub that does fit is 850821-1. Thanks again:ernaehrung004:
On that note how much rpm increase should I see with labbed 30's instead of the stock 30's. Presently running 4900rpm, need a little bump:party-smiley-004: |
(Post 3479794)
| All times are GMT -5. The time now is 05:54 PM. |
